69 gp gas gauge stuck on full
finally took out the gp today and ran out of gas. i thought i filled it three years ago when i put it away. would this be the sending unit float stuck? thanks
I think the trick is to unplug the tan wire in your trunk
Coming from the taillight loom That wire should go to the sender Unplug Turn key on Any difference?? |
i"ll give it a try today. wqhat difference should i see? thanks
well i thought i would get to it but plans changed. definatly this week for sure i will update the results. thanks
| All times are GMT -4. The time now is 01:14 AM. |
