-   64-65 GTO Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=429)
-   -   fan shroud gap (https://forums.maxperformanceinc.com/forums/showthread.php?t=867168)
skinny035 06-09-2023 06:42 PM
fan shroud gap
I have a 65 GTO with a 455 with AC and automatic. I installed a cold case radiator and now have a 1" gap between the top of the shroud and the radiator? I'm sure this is decreasing airflow through the shroud. Is there something I'm missing? An adjustment?
skinny035 06-09-2023 06:47 PM
i noticed that the Harrison radiator is thicker than the cold case if that means anything
geeteeohguy 06-13-2023 04:30 PM
You have non oem parts mismatch. Easily fixed with a strip of heavy rubber mudflap material or a strip of metal. You want the gap sealed for the shroud to work.
skinny035 06-13-2023 04:34 PM
It just looks kinda bad that way. Where does the fault lay, the radiator of fan shroud?
grivera 06-15-2023 10:28 AM
I have the same issue in my 64 with a Champion aluminum radiator.
Any pics of the mudflat or metal mod?
jarhead 06-19-2023 02:34 PM
Ames has the AC seal kits - https://secure.amesperf.com/qilan/De...A&web_access=Y
lucky1 06-19-2023 04:23 PM
Gap.
I experienced the same thing. The replacement was not as thick as my original Harrison. It also had a gap as it sits on the core support.
It cooled better than the original because it more efficiently dissipates heat and does not have to be as thick to accomplish it.
skinny035 06-20-2023 02:38 PM
Here is a pic..It looks aweful
geeteeohguy 07-02-2023 01:50 PM
Attachment 615278
Not sure if you can see it very well. Just a heavy bit of rubber filling the gap. Foam insulation for outside pipes works, too.
grivera 07-06-2023 01:16 PM
Originally Posted by jarhead (Post 6434465)
Thanks - the seal kit is $49 which seems reasonable and the fastener kit is $73 - wow https://secure.amesperf.com/qilan/De...A&web_access=Y
Originally Posted by geeteeohguy (Post 6437420)
Attachment 615278
I can't make it out in the pic
