-   Industry Stuff (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=473)
-   -   1965 Bonneville side molding clips (https://forums.maxperformanceinc.com/forums/showthread.php?t=868296)
1964pontiac 07-31-2023 05:12 PM
2 Attachment(s)
I need 3 clips for the driver side chrome piece that is between the door and rear wheel housing. The holes are 1/4 inches. I've already contacted Restoration Specialties that specializes in clips but they had nothing for my application. Thank you.
GTO.PAUL 08-01-2023 11:17 AM
Clips
I have hundreds of GM dealership clips from that era. However there are no part numbers or bin labels to say what the application is. If you have a pic of what is correct I may be able to help you out. Paul
1964pontiac 08-01-2023 01:17 PM
2 Attachment(s)
Hi Paul,
Thank you for your response. I purchased the chrome piece from Desert Valley Auto and they sent me one clip. The prong is much bigger than the holes in the body. The prong is metal and is 1/2 inch and the holes in the body are 1/4 inches
Cammer-6 08-03-2023 06:25 PM
also try AUVECO
thay are an OEM supplier
1964pontiac 08-03-2023 07:42 PM
Thanks so much for recommending another supplier!
