-   61-66 Big Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=428)
-   -   1963 Taillamps (https://forums.maxperformanceinc.com/forums/showthread.php?t=869034)
misterp266 09-06-2023 02:55 PM
1963 Taillamps
Does anyone know a source for lens to housing gaskets? Ames has discontinued them and I haven’t found them anywhere else. I ended up making back up lamp gaskets out of some round silicon gaskets I found on Amazon. Tail lamps are a bit tougher.
pfilean 09-06-2023 04:33 PM
I suppose those were that dense white foam gaskets. Maybe you can get a similar material from McMaster-Carr in Chicago and cut your own. I had to do that for my air duct to firewall gasket because I didn't want to reuse the old gasket. There are a number of different thickness and density, open or closed cell foam materials to choose from.
