Looking for muffler similar to Dynomax Super Turbo
I need a shorter muffler than the Dynomax super turbos but with similar characteristics, i.e., quiet but still flows well. Need less than 18" overall length for a dual exhaust system under my old F250. Does anybody use a short but relatively quiet muffler that breathes?
The Dynomax Super Turbo 17734 is 2-1/2” offset/offset and has a 14” long case.
It is louder than the 20” long 17749 but does flow pretty well, maybe too loud for what you’re trying to do unless you’re adding resonators. |
I've got Flowmasters (maybe 50 series) on the truck now and they're too loud. Looking for that Dynomax tone but the 17749s are way too long.
I bought a set of each (17734 and 17749). I put the short ones under my '79 10th Anniversary Trans Am (Olds 403) and the long ones under my '67 Cutlass (Olds 330). I didn't find the noise objectionable in either one.
10 4, thanks
As many know, Pontiac used different length mufflers on dual exhaust systems. Would using a Dynomax 17743 & a 17749 on an A-Body help with potential drone?
I have the 16" 17629 Dynomax SuperTurbos on my GTO. Here is what they sound like with 2.5" exhaust with H-pipe and long-tube headers: https://youtu.be/kXVLnazCMtw?si=HLnLT77jF8beTvQK
Helps a lot to use headphones when watching the video. |
Those sound good! Thanks
| All times are GMT -4. The time now is 04:07 AM. |
