Engine Tools For Sale - Round 1
All together, $140 + shipping from 92024.
Venmo: W-Brent-Napier PayPal: [email protected] 1) Moroso Pro Wheel w/ Socket and pointers - $40 2) Total Seal Ring Compressor 4.125 - 4.225” - $10 3) Ring Squaring Tool 4.00 - 4.23 - $10 4) Crank Socket Adapter to Rotate Engine - $5 5) Ring pliers, unknown brand - $10 6) Ring pliers, OEMTOOLS 250B3 - $15 7) Pontiac Dip Stick Installation Tool - $10 8) Pontiac Oil Pump Tube Installation Tool - $10 9) Pontiac Oil Pump Drive Tool - $10 10) Flex / Fly Wheel Hold Tool - $10 11) Camshaft Installation Tool - $10 12) Spark Plug Hole - TDC Tool - $5 13) Spark Plug to Air Compressor Adaptor Tool - $5 14) Piston / Rod Assembly Rod Bolt Rubber Sleeves - $5 15) Spark Plug Thread Chaser - $5 16) Timing Chain Crank / Sprocket Alignment Tool - $10 17) O2 Sensor Socket - $5 18) Feeler Gauges - $5 19) Valve “checking springs” Light - $10 20) Flat and Roller Tappet Lift Tool (Must be used with dial indicator) - $20 |
I forgot a photo. Please see it here.
I'll take the degree wheel, crank socket and flywheel tool.
I will take
2) Total Seal Ring Compressor 4.125 - 4.225” - $10 9) Pontiac Oil Pump Drive Tool - $10 11) Camshaft Installation Tool - $10 12) Spark Plug Hole - TDC Tool - $5 I'll send you a pm |
I'll take:
3- Ring tool 7- Dipstick tool 14- Rod bolt sleeves 16- Sprocket tool 17- O2 socket 19- Checking springs 20-Tappet tool |
Most sold.
I am starting a new thread with more tools from storage and I will include those not sold here in that thread. Thank you all. |
parts
Just received the pars. Everything is as described and really in very good condition. Thanks.
Received mine too, very fast and everything looks great thank you!
| All times are GMT -4. The time now is 10:04 PM. |
