heater bypass in a 55
I am going to assume, and you know what that means. I am almost ready to try and fire up my wagon. I am not sure of the heater system if it leaks or not.
Can I bypass from the intake directly to the lower radiator heater hose inlet, without any issues? It just looks like it would bypass the thermostat to me. Thanks |
Yes, you can do that without any problem. It might take a little longer for the engine to warm up to where the thermostat opens. I doubt you would notice the difference.
It would be the same with heater and defroster connected and heater opened for heat during warmup. |
Thanks Larry.
