-   64-65 GTO Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=429)
-   -   Electric connector (https://forums.maxperformanceinc.com/forums/showthread.php?t=869574)
ejgoat 10-03-2023 09:53 AM
Electric connector
I need a rear lighting harness connector to the ribbon wire for a 64 goat, damaged mine, can,t get in touch with m/h electric to buy one, anyone have one.
Lemans64 10-03-2023 05:15 PM
Can you post a picture of it, have some 64 -65 stuff.
But I'm in Canada so might take a while to get there.
jhnichols2 10-03-2023 09:03 PM
2 Attachment(s)
Here are pictures of the rear lighting harness from my 64 convertible. not for sale but may help you find one.
ejgoat 10-04-2023 10:19 AM
I NEED the black connector on the end of the 1964 GTO rear wiring harness.
ejgoat 10-04-2023 10:20 AM
i NEED THE BLACK CONNECTOR TO THAT HARNESS
Lemans64 10-04-2023 01:06 PM
Isn't that part of ribbon harness?
ejgoat 10-05-2023 12:30 PM
iTS THE BLACK CONNECTOR AT THE END OF THE REAR WIRING HARNESS, NOT ON THE RIBBON, IT CONNECTS THE REAR HARNESS TO THE ROBBON WIRE
jhnichols2 10-05-2023 08:02 PM
3 Attachment(s)
Photos of 64 Le mans convertible body ribbon harness. Black connector is where rear tail light harness plugs into. Are you looking for a male or female connector?
64 very hard to find and not reproduced to my knowledge. .65 harnesses are reversed from 64. I beleive 65 are reproduced.
Lemans64 10-05-2023 08:25 PM
4 Attachment(s)
Not sure which connector you are looking for. Sorry for any confusion, But is the connector by the fuse box or by the rear seat? The dirty connector is on taillight harness at or under rear seat area. Clean connector is at fuse box location. Both of these plug into black connector on ribbon harness.
ejgoat 10-08-2023 01:04 PM
Ribbon connector
Rear lighting harness wires terminate at this black connector that plugs into the ribbon wire has a hook on each side that connects to the ribbon wire
ejgoat 10-12-2023 01:09 PM
CONNECTOR IS IN THE TRUNK BEHIND REAR SEAT, ITS THE BLACK CONNECTOR AT THE END OF THE REAR LIGHTING HARNESS THAT PLUGS IN TO THE RIBBON FROM THE FUSR PANEL
Cammer-6 10-12-2023 02:20 PM
so who have you contacted that makes harnesses?
what was your failure in contacting M&H?
Lemans64 10-13-2023 11:57 AM
Your connector is not like the post 8 picture? That connector is part of the ribbon harness I believe.
