-   Members Helping Members (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=486)
-   -   BMW < dead battery lockout (https://forums.maxperformanceinc.com/forums/showthread.php?t=869723)
Lightfoot 10-09-2023 10:02 PM
My brother called this evening, asking if I had any ideas on how to get the door(s) unlocked on a BMW with a dead battery (his son's car). Key won't unlock the door mechanically, apparently.
At least he is assuming the battery is dead, it could be another problem. Anyway, it's a post 2000 SUV not sure of the model. He thinks the battery is in the rear passenger area, not under the hood. Said he managed to squeeze something down through a cracked window to pull on the inside lever, but it still wouldn't open.
My only guess is if the key fob has a dead battery, maybe the computer won't allow the doors to unlock?
Anyone know if there is an auxillury power-up port on the exterior of the car somewhere? Or have any knowledge about a common quirk of this nature?
Do BMWs use vacuum operated locks? I mentioned that to my brother, but I thought that was mostly only Mercedes, Audi and Volkswagon.
Lightfoot 10-10-2023 10:05 PM
Wanted to get this up here before I did anything else.
A little later I tried searching on YouTube. Got the answer(s) I needed pretty fast. Is there anything that can't be found on YT? lol
Anyways, thanks for looking.
Scarebird 10-10-2023 11:14 PM
well, we're waiting! how was this solved?
Lightfoot 10-11-2023 11:00 PM
Jumper connections to the POS terminal of the license plate light socket and any ground. The trunk light works on some cars that the key will open the trunk on.
Just a jump pack would be enough. Apparently, it only takes minimal voltage back fed through the harness to operate the door locks.
Also, there are some models that have a secret trick where you turn the key a full revolution while lifting the door handle.
Scarebird 10-12-2023 12:02 AM
I wonder how this voltage gets past the off light switch or relay?
