KRE 535 900+ horsepower High Port
***KRE 535 900+ horsepower High Port complete motor For Sale***
KRE MR1 Iron Block KRE 400+ cfm High Port Aluminum Cylinder Heads T&D rocker shafts w/ offset intake rockers Custom roller Militia Race Cams KRE Polar Wind cast 4500 style manifold QuickFuel 1250 CFM dominator Carburetor Oliver Steel Rods SCAT 4.5” Stroke 3” main Forged Crank Ross 4.350” Pistons KRE Aluminum Timing Cover Meziere electric water pump Stef’s aluminum oil pan MSD Crank Trigger MSD Distributor and Plug Wires OE Pontiac style Valve Covers w/ aluminum spacers ***Vacuum pump not included Has 5 dyno pulls and approximately 15 runs since new, have a new combination ready to go into the car. Dyno sheets attached showing power made with single dominator. Has been 8.75 at 155.11 in a 3000 lbs 1972 Ventura with a glide and Protorque Converter. Can provide setup details and time slips upon agreement of sale. Can be setup to ship if needed. $20,000 o.b.o. |
Nice build. Very fairly priced. Couldn't buy the parts for $20K. Steel blocks are in short supply as well. Please add dyno sheet.
Compression?
Motor is sold.
To answer your question though it’s about 13.5:1 Here’s the dyno sheet also |
| All times are GMT -4. The time now is 03:49 PM. |
