-   -   RAIV on Hemmings (https://forums.maxperformanceinc.com/forums/showthread.php?t=870107)
71GP76TA 10-29-2023 06:24 PM
RAIV on Hemmings
RAIV '70 T/A on Hemmings auctions
https://www.hemmings.com/auction/197...lton-nd-448582
turbo69bird 10-29-2023 10:25 PM
Thanks for posting it will be interesting to watch
65madgoat 10-30-2023 01:21 AM
Cool car. $120k you think?
necdb3 10-30-2023 10:20 AM
Not trying to knock the car but would you think when the did the restoration they would put the correct fender supports in. Just a peeve of mine maybe with early 2nd gens. A RAIV is certainly worth it. Don't get me wrong, I'd love to own it!
Norwood 10-30-2023 12:06 PM
Double that
Tellyshavilli 10-30-2023 05:26 PM
Originally Posted by Norwood (Post 6464022)
Double that
Maybe
Formulabruce 10-30-2023 06:11 PM
The wheels are ? " no issues" is what it says.. REALLY?
Shifter issues?
Fender wrong...
For a real investor, Not a flipper.. its not as correct as it should be.
Might go for $165 K .
On the auction writers...
I dislike the more common auction writers languages about items.
Example. " The " correct" transmission sits behind the blue engine" what does " CORRECT "actually mean?
Or , " a proper 3 speed turns the drive shaft" < just stooopid >
" a quadrajet sits atop the intake" , Really ?? Thats it?
" Its said to have the correct gears" , Really, no rear code??
Looked at a 66 Vette Big Block for sale on line. NOWHERE in the ad was the transmission even mentioned, aside from a general " numbers" statement. The Truth WOULD HAVE HURT.. Said like a writer... The giant 427 breathes deep through dual exhaust as it spins the torque converter.... in its BORN WITH Power glide.
I barely could see the shifter gear selector in one pic...
So much is said to make people assume one thing, but not actually saying it. Rant off..
skunkwerks 10-31-2023 08:25 AM
Shifter issues?
Fender wrong...
Agreed,
For this car you would think they would get it correct.
Thing that screams something bad happened to this car body wise is the incorrect front fenders and the rear spoiler gaps. the shape and gap of the rear QP on the passenger side next to the taillight is closed. not the correct spacing. the other side looks twisted.
Body lines and spacing tell a lot about what or how the car was put together.
Also the door the QP body lines do not line up at all.
I know these cars were not perfect when they left the factory but after seeing a couple hundred of these cars over the last 35 years you can tell the ones that were whooied together.
This is not what I would buy for that kind of money.
Tellyshavilli 10-31-2023 10:37 AM
In Hemmings back in the early 90s I passed on it then but checked it out , if anybody needs any info send me a message
Norwood 11-01-2023 08:50 PM
It’s pretty rare that its original block is still in one piece.
65madgoat 11-01-2023 09:13 PM
When the 190 watchers gonna start bidding on it?!?
65madgoat 11-06-2023 05:50 PM
Only at $55k with 3 days left... the 3 bidders and 246 watchers all waiting to the end I guess
RAIV70TA 11-06-2023 07:50 PM
I believe this is the 1st 70' RAIV built in Norwood. Regardless of prior restoration faults, it still has it's pedigree.
65madgoat 11-10-2023 04:25 PM
Asking $189k now....
https://www.hemmings.com/auction/197...ly_marketplace
Baron Von Zeppelin 11-10-2023 07:41 PM
Top bid was 82,500
Nobody really went after it.
Sporting bids
R 70 Judge 11-10-2023 08:00 PM
In all of these years this is the first RAIV auto I've seen. It's not perfect but it looks like a nice car. You don't get many opportunities to buy these
RAIV70TA 11-11-2023 08:22 AM
Then, I'm guessing mine would be your 2nd one R 70 Judge.
71GP76TA 11-11-2023 01:42 PM
Any idea on how many column shift RAIV's are out there?
R 70 Judge 11-11-2023 02:55 PM
With a column shift!! Very cool! :eek:
Baron Von Zeppelin 11-11-2023 05:22 PM
There was a white/blue interior auto on the column Ram4 that sold a couple of different times at the big auctions , several years ago. Was not top notch necessarily , sold for around 100k both times.
In 2006 a friend had just completed a full resto on a 70 Ram4 4spd , white/blue interior.
Showed it at 2006 POCI in South Carolina , was offered 125k
That was full monte at the time.
He turned it down and said next year it will be worth 150k , 10 years it will be double that.
He was pretty much right about it.
