-   SOLD Parts (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=491)
-   -   CENTERFORCE DXF CLUTCH & PP F/S (https://forums.maxperformanceinc.com/forums/showthread.php?t=870236)
65gto69 11-05-2023 07:34 PM
4 Attachment(s)
Used centerforce DFX clutch and pressure plate. This is 11" with 26 spline, still looks like it has a lot life in it.
$250.00 or make offer plus shipping
Thanks,
Mark
jotrout 11-06-2023 01:25 AM
What t/o bearing should be used? Thx
65gto69 11-06-2023 08:55 PM
I would contact Centerforce and let them know what clutch and pressure plate you have and what car this is for and they should be able to tell which throwout bearing should be used.
If using on a traditional Pontiac engine, I would use a throwout bearing for setup which should be your typical GM throwout bearing.
Thanks,
Mark
65gto69 11-12-2023 09:11 PM
to the top
65gto69 11-25-2023 11:04 PM
bump
65gto69 12-30-2023 10:16 PM
bump
65gto69 01-26-2024 01:25 PM
bump
MAKE OFFER!!!!
65gto69 03-18-2024 12:15 PM
bump to top
65gto69 04-24-2024 12:50 PM
BUMP TO TOP
65gto69 07-24-2024 12:30 PM
bump to top
blueghoast 07-25-2024 02:03 AM
Originally Posted by 65gto69 (Post 6516722)
bump to top
How much power will this setup handle ?
GT
65gto69 07-25-2024 12:16 PM
https://www.centerforce.com/i-304995...-disc-set.html
Here is the link to Centerforce site for this setup. It shows holds up to 700 lb/ft torque
Thanks,
Mark
65gto69 07-29-2024 08:32 PM
SOLD!!!
Thanks P.Y.
