'63 389 Tripower upper rad hose
2 Attachment(s)
Do any of you all have a preference or recommendation relative to an upper radiator hose for the Grand Prix?
I see the Ames catalog shows two, either of which would fit based on the description. When I installed the tripower I reused the 4 bbl hose that was on there. The fit is OK but wondering if it could be better. Thanks in advance - K https://forums.maxperformanceinc.com...1&d=1699893287 https://forums.maxperformanceinc.com...1&d=1699893299 |
I think the shorter one with short straight section is the correct one, but is only needed if the large air cleaner is used. The straight section was used to avoid the large air cleaner snorkel .
| All times are GMT -4. The time now is 01:14 AM. |
