-   61-66 Big Pontiac TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=428)
-   -   '63 389 Tripower upper rad hose (https://forums.maxperformanceinc.com/forums/showthread.php?t=870356)
Keith Seymore 11-13-2023 12:37 PM
Do any of you all have a preference or recommendation relative to an upper radiator hose for the Grand Prix?
I see the Ames catalog shows two, either of which would fit based on the description.
When I installed the tripower I reused the 4 bbl hose that was on there. The fit is OK but wondering if it could be better.
Thanks in advance -
K
https://forums.maxperformanceinc.com...1&d=1699893287
https://forums.maxperformanceinc.com...1&d=1699893299
tom s 11-13-2023 12:45 PM
Keith,the one included 64 tripower?The thermo housing in 64 was pointed the other direction?Tom
Keith Seymore 11-13-2023 02:18 PM
4 Attachment(s)
Not sure.
I used what I had on hand -
https://forums.maxperformanceinc.com...1&d=1699899296
https://forums.maxperformanceinc.com...1&d=1699899346
This hose has developed a sort of cut on the underside:
pfilean 11-15-2023 12:09 PM
Original part number for 61-63 P/8 was 538568 for manifold outlet. 538821 for hose. Which should be the PP249 number. Back in 1961 there was a Craftsman News item cautioning to cut 1 inch from the radiator end to prevent wearing a cut where the hose rubbed the left air silencer snout. But I presume the 538821 number had taken that into consideration and if you don't use the big air cleaner anyway it shouldn't matter.
Keith Seymore 11-15-2023 12:42 PM
Thank you;
I looked at it again last night and I think I may have enough length to cut the diseased portion off and put the clamp up higher.
Thanks again -
K
