Pontiac Pulley Set - Early 1969 Short 4" Water Pump W/ PS and A/C
For sale is a matched set of pulleys for an early 1969 Pontiac V8 engine. This is for the short 4" 11-bolt water pump and a vehicle with both power steering and air conditioning. Later in 1969 Pontiac switched to the longer 4-1/2" 11-bolt water pump which requires a different (deeper) upper pulley (9799130). The lower pulleys are the same for either application.
These pulleys have a larger 8" crank pulley and smaller 7" upper pulley to increase the fan and water pump speed for increased cooling in air conditioned cars. Non-A/C cars have a smaller 7" crank pulley and larger 8" upper pulley. These will work fine on a non-A/C car if you want the increased cooling. These will clean-up nicely and look new with a coat of paint. Pulley #9796062 - #9790842 - #9790843 Located in East Texas - 75757 Asking $100 plus shipping |
SOLD
