rear defog/frost switch
2 Attachment(s)
got a bunch of these defrost switch i want to sell .what is the best way to test them before i sell them
2 Attachment(s)
Use an ohm meter.
Between the two tabs… Off = infinity High = really close to 0 ohms Low = some ohms If 0 ohms in high or low it’s bad. Don’t toss it though, it can be used as repair parts or repaired. I would be interested in your “bad” ones. Any chance you have any for the early grid style defrost? Like the one in the picture below? |
You have any pics of the front/back of the ones you are talking about?
The one in your picture is the blower style. |
2 Attachment(s)
And pics of the front?
2 Attachment(s)
1970 blower style switch
Those are later model with the grid style glass that uses a LED light. Notice the back of the one I posted has a tube that an incandescent bulb slides into.
I’m interested in the incandescent tube type and the On/Off blower style. Not sure at the moment how to check the later ones out. Tomorrow I can get some out and check and let you know. |
I want blower style 70.71 like 1st puc with a red fuse. I'll send pics when I get home
Ramairnacho,
There are no fuses or lights on the blower style switches. The blower style does have a wire wound resistor (looks kinda like an old glass fuse). The lights are on the grid style. |
Oh the long red tube isn't a fuse? I thought it was
switch
NICE!!!
nice options
| All times are GMT -4. The time now is 08:08 AM. |
