Ignition Switch Removal 1968?
Ok, so I have the ignition switch bezel turning, but it's not coming off. It is supposed to unscrew once it's turning?
Or do I need to release the bezel or switch somehow using a paper clip in the small hole on the switch? Thanks, Scott |
Take the lock cylinder out first by using a paper clip and turning the cylinder with the key.
Then reach up behind and hold the switch while you turn the bezel. |
Turn the key to the left. Insert a paper clip and push it in while continuing to turn the key to the left. Cylinder should pop out.
Got it. Thanks!
| All times are GMT -4. The time now is 09:14 PM. |
