Wilwood D52 and D154 Rotors, Tuff Stuff Brake Booster and Master Cylinder
5 Attachment(s)
I am selling off all of my previously used Wilwood calipers and other braking components. I have several items available.
Tuff Stuff 2229NC Dual 9" brake booster. This booster is nearly new with about 500 miles on it. It did get scratched up during installation however. Included angle mounts for 60's through 70's gm cars. Functions as new, I'm selling this as the car is on the edge for vacuum and I decided to go to manual brakes. AC Delco 1-1/8" Corvette style master cylinder. Also only has around 500 miles on it. $120.00 + shipping combined. Wilwood D52 dual piston calipers and BP10 pads. These have about 2000 miles on them with over 90% pad life remaining. Designed as a direct replacement of the GM single piston D52 caliper. Will fit any GM D52 mounting brackets with 7.06" floating mounts. 11" or 12" rotors in 1.04" thickness. This is the 6.38sq" piston volume version. $220.00 + shipping Wilwood D154 dual piston calipers and BP10 pads. These have about 500 miles on them and near 100% pad life. Designed as a direct replacement of GM Metric calipers that use a 5.46" floating mount. Will fit 11" or 12" rotors with .81" thickness. These are the 4.12sq" piston area versions Wilwood D154 dual piston caliper, no pads. Same as above but are the 1.98sq" piston area versions. These have about 1500 miles on them. All of the calipers come with their slide pins. $100.00 + shipping |
I’ll take the calibers if they will fit my 79 trans am … pm sent
The D52 or large piston D154 are sold. Customer determining which mount. I'll update which was sold once he measures.
D52 Calipers are sold.
Still have both sets of D154 calipers, the booster and master. |
Update: The small D154 calipers without pads are sold.
The 4.12sq" piston area D154 calipers and BP10 pads are still available, priced at $220.00 + shipping. Booster and master cylinder are also still available. |
All calipers are sold. Still have the master cylinder and brake booster. New price $75.00 plus the ride.
Can you post a pic of the backside of the booster?
| All times are GMT -4. The time now is 09:49 PM. |
