-   71-77 Ventura including 74 GTO TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=438)
-   -   74 GTO door hinges (https://forums.maxperformanceinc.com/forums/showthread.php?t=871593)
Mean Green 01-26-2024 06:51 PM
74 GTO door hinges
I'm trying to remove the doors on my 74 GTO. The hinges are welded to the body and the doors.
Is it possible to remove the hinges without destroying them?
importsmasher 01-30-2024 05:20 PM
I just pull the pins out to remove the door. I've never had the need to replace the welded hinges, so I can't answer that question.
Importsmasher
Mean Green 02-17-2024 03:33 PM
I ended up just removing the pins.
Thanks.
