-   -   Crower Cam Saver or Hylift Johnson? (https://forums.maxperformanceinc.com/forums/showthread.php?t=872211)
ponchjoe 02-25-2024 10:02 AM
Hey guys, I am attempting the dreaded HFT cam installation in my 400 for my 62 GMC. I have a set of Hylift Johnson’s I bought from Paul K many years ago. I see Crower has a “cam saver” lifter.
Which is the best choice and why?
steve25 02-25-2024 10:04 AM
I would pm Paul on that question.
64speed 02-25-2024 10:10 AM
I’m using cam savers on my Crower cam and they seem good
JB Eng Wis 02-25-2024 10:38 AM
I would say both are Good to use.... its just a roll of the dice
I you are able to do the weak single spring on break in, then the stars are all in aline...
Plus a good choice of break in oil.
67Lemons 02-25-2024 10:43 AM
Stick with what you have, the general consensus is that the lifters made in the past are better than what we are seeing today plus the HJ’s are a quality USA product regardless.
grivera 02-25-2024 02:04 PM
The ones you already have on hand
Tom Vaught 02-25-2024 02:31 PM
X2
Tom V.
Tom Vaught 02-25-2024 02:32 PM
X2
Tom V.
i82much 02-25-2024 02:42 PM
can you have lifters drilled for an oiling provision?
ponchjoe 02-25-2024 09:20 PM
I thought it was the cam cores that were the issue???
67Lemons 02-25-2024 10:37 PM
Everything that I have read & heard points to lifters not cam cores. Plus it’s pretty much one or two suppliers for cam cores vs all the different suppliers for lifters.
68WarDog 02-25-2024 11:24 PM
Are you referring to solid roller lifters? I've had it done twice by Crower for the needle bearings. No other lifters would benefit or needed.
i82much 02-25-2024 11:28 PM
yeah i knew abt the solid rollers but wasnt sure if you could do something with a flat tappet as well. i googled a bit and couldnt figure out what a "cam saver" lifter really is ... how do they help?
Nobuddy 02-26-2024 01:28 AM
Crower "Cam Saver" is only for flat hydraulics. It is a flat ground in the side of the lifter from the oil band to the face as a controlled leak for extra oil to the cam lobe/lifter face. So if you need extra oiling, it might help. Other ways to do this include cutting a groove in the lifter bore down towards the camshaft. There used to be kits with a guide bushing and cutting tool that you could add the grooves into the lifter bores by hand. You would have to hone afterward. I've never used either method so no opinion if or when they help.
The tiny holes in the face of the flat lifters are only for solids. Crower calls their version Cool Face. Doesn't work on a hydraulic since it would leak down all the internal pressure and fail the automatic lash adjustment.
242177P 02-26-2024 05:05 AM
Rhoads offers a $29 "Super Lube" groove.
https://forums.maxperformanceinc.com...1&d=1708938311
Dragncar 02-26-2024 05:34 AM
That groove is interesting. You might be able to do it yourself if you are careful and have some equipment.
Formulajones 02-26-2024 06:39 AM
I always use the lubed lifters on flat tappets solid and hydraulic. Just piece of mind for me. But if you already have a set of Johnson lifters I'd use those and roll with it.
i82much 02-26-2024 09:22 AM
makes sense, thank you!
JB Eng Wis 02-27-2024 12:54 AM
I have never seen where the lifter is Grooved above the oil band, like show in the Rhoads pic....
Has anybody else? makes no sence to leak oil up into the lifter valley.. IMO
Bill S 02-27-2024 09:23 AM
I had those lifters along with the Mellings 041 cam. Still had two lifters / lobes fail.
