Anyone know what this is?
I found a couple of these on the front driver's floor of my car. Does anyone know what it is? It's about 1 1/2" long.
I guess my usual McGanzer Flange comment would be pointless now.
He also posted about a loose shifter. I was able to put two and two together. Hard part was searching for a picture... |
Okay... So it's a spacer for that thin bolt that goes sideways on the shifter? I was thinking the loose, sloppy shifter question and this piece might be related but wasn't sure.
It's more of a positioner. It keeps things from floating around.
Got it. Thanks so much!
I believe it's called a pivot bolt bridge plate.
At this point in my life, I’m not sure of anything.
Originally I thought it might be a muffler bearing support bracket
Only on the older ones, the removed those on the lubed for life models.
| All times are GMT -4. The time now is 02:18 PM. |
