Engine dip stick id
4 Attachment(s)
Well
Im a little confused on the year application Of the non a/c dipsticks i have Any information help Such as what year has the holes near tip What year is 6 quart?? What years were 5 quart …. Long handle - short handle etc Thanks. Scott |
100 views and nobody has an original dipstick
In their 67-72??? |
The small fonts 5 Qts looks like the 9793342 1968-on rod.
6 Qts were used on 1967 engines (and 1966 as a service replacement). 5 Qts on all others. |
3 Attachment(s)
My '67 GTO with AC has the 6 QTS. and long handle as yours. It's just longer.
4 Attachment(s)
the same stamping and long handle, except one is longer for AC. |
very helpful
thank you ... 6 qt going into my fresh 67 WG 428 4 bolt and marking the others for the future... Scott |
isn't that top 5 quart one a later dipstick?
I cannot recall if it was a 73 or 77 engine that I had it in, but I know I had one of those in an engine; I recall this because it actually broke the end off at the first hole below the add arrow... |
They didn't have (or use) SE oil until around 74 or so? (bottom one)
:confused: |
I´d say the bottom rod #9793342 is the current SR rod for 1968-on Pontiac V8´s
Timeline for API specs: |
Thanks for the chart Kenth, little earlier than I remember. Of course probably didn't use SE until 74? (cheapskate)
:D |
great info!!!!! thank you gentleman ... I think that one was from a late 73 455 that had a freeze crack I recycled
any ideas on long and short handles.... ?? |
