-   -   69 GTO Convertible Frame (https://forums.maxperformanceinc.com/forums/showthread.php?t=872651)
MarkS57 03-19-2024 12:32 PM
Hi all,
My friend is trying to rectify some shoddy work done by the PO of his 69 GTO convertible. He took it to a reputable restoration shop and got a load of bad news. 1st up, the frame is twisted and therefore needs to be replaced. As this thing sounds like a frankenmobile, does the convertible have a different frame from a hard top? Figured it might and there might be an incorrect frame under the car.
bluejudge 03-19-2024 02:08 PM
Originally Posted by MarkS57 (Post 6493003)
Hi all,
Yes two different frames. Convertible is boxed and the HT is open. I believe the best way to check the frame is it should be put on a frame table and measured, unless you see it was in a wreck or rusted out. Good Luck, Marc.
Cammer-6 03-19-2024 02:59 PM
just curious how twisted a frame needs to be to warrant replacement.
Many a 69 frame has been put back in shape on a good frame machine.
Heck Ive used many unorthodox methods to get them straight.
Big trees,chains,come a longs,heavy equipment,if done correctly will suffice.
nas t eh 03-19-2024 03:02 PM
If the repairs or straightening needed was extensive or unreasonable. I think I’d be tempted to replace with one of the aftermarket frames available.
Eg. Roadster shop frames start at $13,000, that would be a great foundation to build a nice convertible on.
MarkS57 03-19-2024 03:27 PM
I wondered the same thing myself but the way this thing drives (I drove it), it's a real mess, almost dangerous. That's why I was questioning what is underneath. While the frame, suspensions & engine are a mess, the body itself is gorgeous.
Cammer-6 03-19-2024 04:31 PM
a simple string and plumbob can tell a lot in just a few minutes
graygator 03-21-2024 12:02 PM
My 69 Lemans convertible has apparently been hit in the front and maybe the rear as well. The frame was bent in more than one way. Additionally, when I was troubleshooting how bad it was, my measurements did not make sense. I had the body off and the suspension assembled with wheels and tires. The wheelbase on each side didn't match the frame measurement deviation. Then I looked down at the rear axle and it was visibly bent! The previous owner had been driving it that way.
Anyway, I found a shop who agreed to straighten the frame for $800 (in 2015). Good luck, none of the other collision shops wanted the cash business, they are setup to do insurance work. This shop was a friend of a friend and that's the only reason they were interested.
I am pleased with the end result. Make sure they check and fix the front extensions or the radiator support won't line up.
Tuske427 03-24-2024 08:30 PM
if you do replace the frame- be sure to get a 2 door frame. the 4 door, station wagon and el camino ones look similar but have a longer wheelbase. It’s possible to cut and weld it to size but more work involved. Fab skills vs time/ money, etc. many posts online about this subject. Also, should you locate a 2 door hardtop frame as mentioned it won’t have the boxed rails which would be more critical for a convertible as it lacks the body structure but there are kits out there to reinforce these frames as the factory convertible ones seem to command a higher price. it might be cheaper to go this route. an example of a reinforcement kit: https://www.opgi.com/chassis-suspens...r-ch30614.html hope this is helpful
north 04-19-2024 03:29 PM
btw, good news is that basically any 2 door (112" wheelbase) 68-72 A body frame will fit regardless of GM division. As mentioned, convertible frames are dimensionally identical to the other 2 door frames but had boxed side rails that were factory welded to a coupe frame C sections. Convertible frame also has heavier section over the rear axle. Inversely the door 2dr post sedan frame looks the same as the hardtop one but has thinner sections in some parts of the frame.
68bobcat 05-31-2024 05:14 PM
I saw this on facebook marketplace. the 69 cutlass convertible fame is what you are looking for. Not sure about what repairs it would require....
https://www.facebook.com/marketplace...9895178686088/
north 05-31-2024 06:32 PM
Looks crooked and has significant rot, as expected for upstate NY
GTOnly70 06-01-2024 12:33 AM
That frame is a rusted mess.
cpotter45 09-10-2024 10:36 PM
Need a 68-72 GM A-body frame for convertible
Does anyone have a lead on a GM A body frame for convertibles, '68-72? A Chevelle, Cutlass, 442, Skylark, GS, GTO or LeMans all use this same frame (i think).
I currently live in SC but I'm gonna guess something from the southwest US might have a better chance of not being a rusted, rotted mess.
Mine is literally Swiss Cheese right where I need to bolt the rear end. *face palm
b-man 09-10-2024 10:55 PM
Post a parts wanted ad in the appropriate classified forum.
The chances of finding a frame from someone reading this tech thread is rather slim.
Tuske427 10-31-2024 12:18 AM
Frank's Pontiac parts. check back often as frames just pop up from time to time. it's where I got mine (still shown on the website on the right, lol) https://frankspontiacparts.com/usedparts/gtoparts2.htm
Tuske427 11-27-2024 12:11 AM
just saw this convertible frame on FB marketplace
https://www.facebook.com/marketplace...e-5b11e18258a4
north 11-27-2024 01:11 AM
That is a sweet looking frame! 68 4 piston brakes too! Even ball joints look factory.
