fast xfi sportsman
i have a couple of the fast xfi sportsman kits one has all tbe ls adapters to run coil on plug etc etc, the other is tbe same kit without the add on harnesses for ls. 303000 kits. it has both distributor connectors and crank trigger connector. i have a dual sync dizz, im trying figure how or if its possible to trigger coil on plug through the dual sync, i know holley sells a harness to do that with their kits
| All times are GMT -4. The time now is 01:31 AM. |
