-   Suspension TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=421)
-   -   Custom sway bar? (https://forums.maxperformanceinc.com/forums/showthread.php?t=872838)
WQ59B 03-27-2024 10:02 PM
Custom sway bar?
Have a vintage O/T GM with a factory front sway bar of only 11/16". Checking if Chevy's bar from the same generation is an interchange (won't be, guaranteed)- there is a 1" bar available to those guys.
Would like to bump my car's bar up to more like 1" but there is zero aftermarket support here. 'Used to be' you could get a custom sway bar made, thicker, patterning off your factory bar.
Anyone know of a company that still does this? Bar is a very simple 'U' with just the 2 bends. Thanks.
Scarebird 03-27-2024 10:17 PM
What do you wish to put it in?
WQ59B 03-28-2024 01:11 AM
'59 Invicta coupe.
WQ59B 03-28-2024 01:35 PM
Eye-to-eye center dimension is 43".
Bar 'drop' is 7.75" from eye center to center of main straight.
Impala bar I was eyeballing is 39" eye-to-eye.
WQ59B 06-21-2024 11:46 PM
Carolina sway bar quote : A grand.
694.1 06-22-2024 02:08 PM
There is Sway-A-Way in Chatsworth, CA. Worth a try.
Oldsmobiles usually had bigger front bars, maybe try a '59 88 or 98?
694.1 06-22-2024 02:13 PM
WQ59B 06-22-2024 03:10 PM
Will try & find a spec.
Found Cadillac's: 47" eye-to-eye.
GM '59-60s are 100% unique underneath (by DIvision), and by a couple shots of the underside of an O-59- it's a different bar by the contour... but will keep hunting. Seems to be my only hope.
694.1 06-22-2024 05:11 PM
Ah, Invicta = Buick. My bad.
55-57 GMs were also division unique. Hard to figure.
My '57 actually has a slightly modified '56 Buick bar for a modest improvement.
I had explored getting a small run of bars made but was a little leary of eating the cost for 10 or 20.
But larger application than just '59/60!
WQ59B 06-26-2024 10:03 PM
Sent pics and Addco got back to me- they're willing to make a 1" bar to match mine for $415.
That's acceptable to me - anyone have any feedback after using Addco bars?
Tempest 07-16-2024 10:46 AM
check out post #669, on page 34, in the 'Lobby' section in the thread 'What did you do you to your Pontiac today'
Bill Bowman1 installed an Addco bar on his 65 Catalina.
He may help
Good Luck
WQ59B 01-19-2025 02:42 PM
New 1" sway bar came in the other day. Looks very good, matches up well with my factory 5/8"+ bar. Addco was good to work with, tweaked dimensions until I was satisfied. Won't be going on for a while, but :thumbs up:
Skip Fix 01-21-2025 08:12 PM
I got a rear Addco bar for my 73 Chevy truck that was either too narrow or too wide and they made up a new one the correct size!
jhein 01-23-2025 01:54 AM
I'd say if that's in your budget and it's what you want, it's a no brainer. I have an Addco rear bar on my TA. You can see it's not factory, but it fits and functions perfectly.
https://i.imgur.com/DfZ8GLpl.jpg
