-   Exhaust TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=422)
-   -   Ram Air manifolds were powdered coating including the flanges (https://forums.maxperformanceinc.com/forums/showthread.php?t=872903)
form74 03-30-2024 02:10 PM
Should I remove the powder coating off the flanges before putting them on the the heads are with the gaskets be good enough they seem pretty flush, but I don’t want to leak either
Red80TA 03-31-2024 08:07 AM
I'd run a file across it all just to may flat, even if coating remains. The powdercoating can have a slight texture and waviness that doesn't seal in all situations.
gman005 04-19-2024 04:38 PM
Use the remflex gaskets Gary and you will be fine.
400 4spd. 04-26-2024 02:11 PM
X2. I started using them more than 20 years ago.
