421 Block - Sevice Replacement?
4 Attachment(s)
A friend just bought a 1964 421 block, standard bore,. Faint code on the front. He was wondering if it’s an SR block. Either way, it’s a cool score. Pics below:
4 Attachment(s)
More
Real nice!
Dare I ask how much he payed for it? |
He’s keeping that private for now…
Service Replacement wouldn't have an eun on it
What's the engine code for it? :confused: |
He says it isn’t legible
Just note the ALL service replacement blocks came with rings and fitted Pistons .
Good to know- assembled?
IMO a freshly shot peened used block. Nice find though.
Yes, the rings where on the pistons and the pistons where in the bore.
The front 2 four bolt caps are missing the outer bolts.
I never realized that the 64 motors did not use a full length windage tray and still had the bell housing reinforcement ribs from the 425 trophy motors.
Maybe you missed this thread on 1964 389 and 421 blocks: https://forums.maxperformanceinc.com...d.php?t=772995 And my 1964 421 HO build, both threads show the windage tray setup used on 1964 and earlier engines: https://forums.maxperformanceinc.com...d.php?t=771741 |
It’s been a loooong time, but I had a 389 425 T block for a while and just forgot about the windage tray deal.
for sure 64 block,has provision for block mounted starter.JMHO,worth the same as any std bore 3 1/4 main 4 bolt block UNLESS you need a SR or numbers matching code or vin to a car you might own.Nice clean block.Tom
I think the correct term was "fitted block"no crank or rods.Tom
Xs 2 with the above.
Sorry I should have been more detailed. |
All great info - will pass onto my friend
