-   EFI Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=570)
-   -   Holley efi msd 23843 (https://forums.maxperformanceinc.com/forums/showthread.php?t=874115)
mysticmissle 06-03-2024 01:27 PM
Just talked to msd and they say the steel melonized gear that comes with this distributor "should be" compatible with a billet steel
Roller cam gear
I have brass and poly gears on hand but if this $500 distributor has a good gear I'd rather not put a $125 gear on it any experience? I mean who is putting a $4500 efi set up on a flat
Tappet cam? Lol
mysticmissle 06-12-2024 07:31 AM
posting incase anyone has this same question. Butlers website clearly states the MSD Holley Engineers cannot confirm the gears will last with certain roller cams. I swapped the melonized gear out for a bronze one in its current configuration. Likely will get composite at some point.
