Coat hook
In my 73 I have the rear coat hooks …I also have the shoulder belts that are wrapped up and are placed up against the headliner …can someone with a 73 post a pic for location. I’ve just installed my new headliner cardboard backed into the car and just looking for verification on install…for the rear hooks …I may also be looking for one hook …my son made one for me with a mold from the original so not sure how the copy will work…thanks
I'm interested in this as well, since I am switching over from a bow-type to the cardboard type.
I suspect they would be in the same location as the bow-type though. * . |
U have a pic of one installed with the bow type
2 Attachment(s)
Here's each side. It looks like they very a bit from side-to-side so be sure to find the screw hole before you install.
https://forums.maxperformanceinc.com...1&d=1718667972 https://forums.maxperformanceinc.com...1&d=1718667966 |
Hmmm perfect thanks I need to take that upper trim off and get some of those clips to attach to the roof think theres 3 a side there the white clips that twist into the trim then get pressed into the roof need to find them locally…appreciate the pics
No problem. I think the last time I got some of those clips Autozone had them. They're still pretty common.
Excellent, thank you SD73!
| All times are GMT -4. The time now is 11:55 PM. |
