69 Firebird cigarette lighter wiring
So I am doing some work behind the instrument cluster on a 69 Firebird. This car has a working Casco style cigarette lighter but wanted to change it over to the original Rochester style.. the old casco has a power and a ground wire, where the Rochester only has a single hot wire? Where does this type of lighter ground? The cluster that it mounts to is plastic.. do you just ground the housing to a ground wire??
I'm not real sure on this, but think it should be the ground for the dash:
(the arrows point to the straps that ground it) https://forums.maxperformanceinc.com...1&d=1721304631 It might be better to post your questions in the 67-69 Bird section also. :) |
Thank you for the information, this is helpful!
2 Attachment(s)
Here is a picture of the ground straps on my dash
| All times are GMT -4. The time now is 08:37 AM. |
