Can 1964 and 1973 Pontiac blocks use the same headers?
Will 3” headers for a 1973 400 block, also fit a 1964 389 block?
3 in what?
3” headers?
Is that the collector size because it sure can’t be the primary pipe size. All Pontiac blocks are dimensionally the same externally, the same physical size. If both have D-port heads (used on 99.99999% of Pontiac engines) which is highly likely then yes of course. Pontiac heads can be interchanged onto any Pontiac block. And please let’s not bring up the short-deck 301 and 265 blocks that 99.99999999% of us don’t want or use. |
This is my first Pontiac, so please forgive my lack of knowledge on the subject. Thanks. |
If your Edelbrock heads have round exhaust ports then the 389 would have to have round port heads too for the headers to work. 389 engines never came with round port heads.
Edelbrock in recent years did produce D-port heads (two center exhaust ports look like the letter D back to back) so it’s possible your headers from your 461 would work. As long as the type of head as in exhaust port style match your headers will work. Keep in mind that round port Edelbrock heads will have a flat on the exhaust port floor at the port exit flange but they’re still considered round port. |
http://forums.maxperformanceinc.com/...d.php?t=636309
From the Street forum Tech Thread Archive, round port and D-port head differences. The differences between them are pretty easy to spot. |
| All times are GMT -4. The time now is 07:23 AM. |
