-   Electrical Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=424)
-   -   starting issues after short drive (https://forums.maxperformanceinc.com/forums/showthread.php?t=875320)
69gp400 08-05-2024 01:20 PM
so i changed starter ,battery and alternator after i drive for half hour or so and car will not start up until i wait 15 minutes only thing i did not change was voltage regulator. all wire connections are clean and tight. so whats next?
GOAT8U2 08-05-2024 04:40 PM
Fuel tank vapor lock maybe, try opening cap if it doesn't start again and see if that helps. I got a remote tank filter setup and after a fill up sometimes it'll spit a tad out the filter if I do say 30 minutes on a hot day, damn.
Lemans64 08-06-2024 01:37 AM
Doe the engine turn over properly? New starter but the cables could be bad causing hot issue and slow crank?
Distributor advance seized in the advanced position making it hard to turn over when hot? Give us some more info to try and make
a better diagnosis. Engine size, Battery size. Stock engine? Turn over find but won't fire?
george kujanski 08-06-2024 10:04 AM
Yep...HOW does it not start?
George
69gp400 08-06-2024 12:39 PM
i did notice the cables do get hot. it is a stock 400 with no mods. it cranks maybe three times then nothing. i took the car today to have new mufflers put on and i told the guy not to shut it off until on lift. he called me like twenty minutes later after testing the system and said i had a bad battery so off to get new battery. the battery i tried before was fully charged out of my truck and did the same exact thing.so for 65 bucks i'll get a reconditioned battery. purchased many batteries from this place so they are good.
Goatracer1 08-06-2024 03:57 PM
Cable connections are one of the last things people check. Remember there are TWO ends of each cable. Often times it is the engine end that is either dirty or has paint under it.
GOAT8U2 08-06-2024 04:48 PM
So it was loose cable, corroded cable, bad cable ground or just a low amp cell battery?
69gp400 08-06-2024 07:07 PM
well just picked up my car and the exhaust sounds great he added a cross over pipe also. so tomorrow i will go get a battery and new cables and hope for the best. thanks and i will post later tomorrow
69gp400 08-07-2024 12:11 PM
well new cables and battery problem solved .
GOAT8U2 08-07-2024 12:27 PM
Good to hear, not too financially damaging either.
Cables and connectors are usually the sleeping devil right in your face.
69gp400 08-08-2024 03:59 PM
yes cheap fix for battery and cables. i did have a rebuilt starter and alternator that i switched out. the car sat for six months over the winter and started right up so i was not thinking battery for starting issues i guess i am losing my touch.
