-   -   1973 Trans Am updates (https://forums.maxperformanceinc.com/forums/showthread.php?t=875856)
napster 09-02-2024 06:03 PM
New Paint Job, Total Rewire of car, bigger cooling fans that you can hear go on when I go to the front of the car. Both fans are Rallye 16" and pull 4,000 cfm. New overflow reservoir for radiator was installed along with Autometer gauges for oil pressure and water temperature. The gauges were installed in the spot where the 8 track tape player would go. Dynamat was installed for sound purposes. Last item was a Ridetech bolt in 4-link installed to run coil overs and BMR anti-sway bar was installed upfront. A Ridetech rear sway bar was installed as part of the 4-link kit. Also, major work was done on the rear exhaust so the tailpipes would look stock placement.
https://youtu.be/7ejfm83NhdE
PAUL K 09-02-2024 06:10 PM
Nice!
grivera 09-02-2024 06:26 PM
F’n love that car!! Fantastic job - sounds and looks awesome. Thanks for posting link.
67Lemons 09-02-2024 06:26 PM
Sweet!
jhein 09-02-2024 06:36 PM
Ver nice!
napster 09-02-2024 06:40 PM
5 Attachment(s)
Here are some pictures from the video.
jhein 09-02-2024 06:53 PM
Looks great! What size tires are those?
napster 09-02-2024 07:35 PM
Thanks! 255/60/R15 all the way around.
BLUE TA 09-02-2024 10:49 PM
l love your car and the color. BLUE TA
Verdoro 68 09-02-2024 11:27 PM
Man, that thing sounds tough!
napster 09-03-2024 09:28 AM
Only other item that might be changed is the steering box. With the change to the back it makes the front seem loose now. If I'm not mistaken the '73 steering box is 3 full turns lock to lock and the WS6 is 2.5 turns and should bring back the quick response. Only have to see if the WS6 steering box will clear the new fans.
kingbuzzo 09-03-2024 11:55 AM
Just wow....
I just did the borgensen and it is nite & day better than my stock unit...but I guess you can't stray too far from stock with that beauty!
napster 09-03-2024 04:20 PM
Originally Posted by kingbuzzo (Post 6524494)
Just wow....
Kingbuzzo,
Thanks for the comment. However, not realizing what you said confirms what I have been trying to do with this car and that is to keep it looking as cosmetically stock as possible with a lot going on underneath.
Here is a link that will show you what I'm talking about:
https://forums.maxperformanceinc.com...d.php?t=839167
kingbuzzo 09-03-2024 05:09 PM
amazing upgrades...
Jim Moshier 09-04-2024 10:26 AM
Sweet looking ride! Now its time to enjoy it. How long was it in Paint jail?
napster 09-05-2024 09:54 AM
Thanks. Roughly three months.
