'71 TRANS AM HEADLIGHT SWITCH CONNECTOR QUESTION
I am replacing the headlight switch and its connector in my '71 T/A.
As you can see in the pics below my original headlight switch connector has melted a bit over the years. In researching replacing the connector, all of the repro pigtails have 5 brass terminal connectors inside. But as you can see the original has 6 terminal connectors. I decided to just put new terminal connectors on the original wires and insert them into a new connector (last pic). So it will have all 6 terminals as it was born with. Just curious why all of the reproduction connectors on the market have only 5 brass connectors and how that works in the car when the original has 6. Interestingly, the factory wiring diagram shows all six (see below as well) Thanks! https://hosting.photobucket.com/imag...720&fit=bounds https://hosting.photobucket.com/imag...720&fit=bounds https://hosting.photobucket.com/imag...720&fit=bounds https://hosting.photobucket.com/imag...720&fit=bounds |
Halogen headlights can cause the melt.
What I did notice when I had the connector (attached to the headlight switch) in my hands and I turned on the lights, the connector got very warm. |
| All times are GMT -4. The time now is 07:20 AM. |
