-   61-63 Tempest & LeMans TECH (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=427)
-   -   63 Lemans 4cyl Timing Cover (https://forums.maxperformanceinc.com/forums/showthread.php?t=876121)
PLongen 09-17-2024 06:30 AM
Has anyone used the aftermarket timing cover from Ames on the 4 cylinder engine?:
https://www.amesperf.com/parts/searc.../?term=+LN482P
:usflag:
tom s 09-17-2024 10:22 AM
Does your engine have a 8 bolt cover or a 4 bolt?I believe the 4 cyc use a water pump with shorter vains.Tom
PLongen 09-18-2024 07:07 AM
mine has a 4 bolt but the casting is very pitted.
tom s 09-18-2024 09:57 AM
You will want to find a 63 4 cyc 8 bolt water pump.Tom
Peter Serio 09-18-2024 12:19 PM
4 or 5 years ago on this forum there was a thread on the 62 & 63 Tempest water pumps and in that thread there were photos of the back sides of pumps side-by-side and there was a specific 4 cyl water pump (for both '62-63 4 bolt and '63 8 bolt timing covers).
Something about the fins on the back of the impeller were different between '63-326 V8 cars and the 4 cyl. Either shorter fins and/or fewer of them.
Radman 09-20-2024 08:19 AM
2 Attachment(s)
It took me a while to find this one. Purchased it while I was working on my 62. Check the casting numbers, I think that it will fit your 63. PM me if you want the part. Also are you a member of the Little Indians car club If not, you should join.
63Banshee 09-21-2024 05:28 AM
V8 pump on a 4cyl isn't a problem. 4 on an 8 will cause heating issues.
PLongen 09-24-2024 06:29 AM
PM you
PLongen 10-07-2024 07:28 AM
Hope I can find a water pump now. Nobody seems to have any.
