-   -   New line of camshafts at butler, max HP series. (https://forums.maxperformanceinc.com/forums/showthread.php?t=876275)
djustice 09-27-2024 09:13 AM
Looks fairly agressive, i'll be bench racing these in my head.
https://butlerperformance.com/c-1459...ollercams.html
PAUL K 09-27-2024 09:44 AM
The old Stage 1,2 & 3 deal.
Interesting, I've seen the specs for the World's Fastest NA Pontiac, turbo charged Pontiac and supercharged Buick and none of them were close to the specs on that link..... Things that make you go hmmm.
Thanks for posting
zippy 09-27-2024 10:21 AM
This has me ??? Lobe sep is ground into cam and cant be changed
BP/Comp Recommended Cam Degree
For 110 Lobe Sep.- Install Int. Lobe CL to 106
For 112 Lobe Sep.- Install Int. Lobe CL to 108
For 113 Lobe Sep.- Install Int. Lobe CL to 109
For 114 Lobe Sep.- Install Int. Lobe CL to 110
PunchT37 09-27-2024 11:30 AM
Yep.
112 sep at 112 icl is “straight up “. 108 would be 4 degrees advanced.
rjpaige3 09-27-2024 11:38 AM
It makes more sense if you replace "for" with "if". Whichever cam you get, install it 4 degrees advanced.
johnta1 09-27-2024 02:00 PM
In the For 110 Lobe Sep.- Install Int. Lobe CL to 106 example, the 110 Lobe Sep. is the Lobe Separation Angle (LSA).
This is angle between the Intake lobe and the Exhaust lobe. (not changeable)
The Install Intake Lobe CL is the Intake Lobe center installed at 106º. (for 110º it would be Int & Exh both at 110º)
This can be changed. But it also has the Exhaust Lobe 110º separated from the Intake Lobe still, but the Exhaust Center line will be different due to the whole camshaft being advanced.
zippy 09-28-2024 11:12 AM
Ohh I get it now LOL DOHHH
i82much 09-28-2024 01:23 PM
why does the lobe lift stay so consistent as the durations go up? valve spring availability?
