-   Electrical Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=424)
-   -   Weird Dash Light Gremlin (https://forums.maxperformanceinc.com/forums/showthread.php?t=876619)
SD421 10-18-2024 11:36 PM
Hi Anyone,
Dash Lights work when the ignition is off but turn the key to “RUN ” and even START position and they go out.
Any ideas?
Thanks,
Don
SD421 10-19-2024 01:53 AM
It was the dash black ground wire at the pedal bracket.
It wasn’t grounding properly.
Lemans64 10-20-2024 11:28 AM
Glad you got it figured out, was gonna comment about a Ground issue, but not a 66 guy so was waiting for others to comment, but you got it handled.
Nice work. Bad grounds do weird things.
pfilean 10-21-2024 09:56 AM
Grounds will drive you crazy. For most unexplainable electrical problems look at the grounds. Had a problem on an old truck recently. Turn on the parking or headlights an everything in the dash would come on. Turn indicators. high beam indicator, everything on made it look like Christmas. Activate a turn signal and it would over ride the signal and flash it all. Cleaned up the light grounds on the core support and that seemed to fix it all. I hope.
