Thoughts On This Ring Gear & Pinion
5 Attachment(s)
I just picked up these 3.07 gears to swap out my 3.73’s for a more friendly rpm range.
Can someone look at these pics and tell me what you think? I picked them up for $150 as they were listed in “great condition”. Thanks, Don |
I dont see anything disqualifying i will just say its measurably harder to set up used gears not knowing previous backlash but doable
https://forums.maxperformanceinc.com...9&d=1731032765
Does the "2" represent pinion depth variance? If not, getting pinion depth right will be a guessing game, which is going to make getting the mesh correct even more difficult. |
Photo #2 looks like the ring gear teeth are galled but I don't see corresponding look on the pinion teeth. Are those teeth as rough textured and pitted as the picture makes them look?
3 Attachment(s)
What the hell are all the punch marks on the face of that gear?
The pinion depth is designated by a 2-digit code for that 12-bolt ranging from 40 to 50. A 45 designates a specific depth (can't remember what it is, have it written down) and numbers below subtract 0.001" per increment and digits above add 0.001" per increment. It can be stamped into the tip of the yoke end. I just checked a 3.07 12-bolt pinion and it is written (grease paint?) on the face of the gear on the bearing side and is a "45".
https://www.hbassociates.us/Lumina_Cam_Bulletin_002.JPG https://www.hbassociates.us/Lumina_Cam_Bulletin_003.JPG |
My opinion: the gears can be used, but may be a bit noisy. They are not 'junk'. You may not even hear them over the exhaust being dumped out of your Tribal Tubes from that tripower 421 you're packing. :) |
3 Attachment(s)
Buff that light rust with 400 grit.
My first impression is the gears were media blasted to hide defects.
Yep. Took out the rust and left the pockets.
Definitely media blasted to hide defects.
Looks like the ring gear is still dusted with blasting media. No set of used gears should like like those ones pictured. |
IMO, they will work but they will probably be noisy. I don't like ANYTHING bead blasted. I've seen more ruined carbs, engine cases, valve covers, you name it. Once it gets 'frosted' there's no going back. |
| All times are GMT -4. The time now is 11:23 AM. |
