-   -   need specs? Crane CC-290 29691 solid lifter cam (https://forums.maxperformanceinc.com/forums/showthread.php?t=877245)
GTO-relic 11-20-2024 04:00 PM
I have this solid mechanical lifter cam, have a rough idea what it is, but not exactly.
box says:
Crane CC-290
with Crane part # 284691
(see pic attached below)
cam is stamped CC-290 on front face as well.
does anyone have an old Crane catalog that has it listed ?
I've found listings for BBC, SBC using the -4691 suffix, but they differ for every engine.
It's a used cam. I can measure .313" intake lobe lift, .329" exhaust lobe lift,
that would be .470" intake lift, .494" exhaust lift, with zero lash.
I'm assuming it's 290 degrees duration seat to seat, but may be slightly more.
it has a little wear on it, on the tips of lobes. but not a lot. good usable cam yet.
please post if you can, thanks.
Joe's Garage 11-20-2024 04:29 PM
Here you go.
Copied this page from a Crane catalog from somewhere.....
Part #284691
intake / exhaust
246* / 256* @ .050
.483" / .506" lift w/ 1.5s
.531" / .556" lift w/ 1.65s
lash .020" / .022"
112 centerline
PAUL K 11-20-2024 04:31 PM
They had a CC290A-NC "Commander" listed in the 1984 catalog
290/300 adv
248/258 .050
.500/.525
112 LSA
.022/ .022 Lash
Jay S 11-20-2024 05:28 PM
290/300 adv
248/258 .050
.500/.525
112 LSA
.022/ .022 Lash
LOL. That is the same cam I just mentioned in the Howard thread that was symmetrical. I have have a lot of measurements for that profile.
GTO-relic 11-20-2024 06:51 PM
Part #284691
intake / exhaust
246* / 256* @ .050
lash .020" / .022"
112 centerline
thanks guys, I owe ya's all one...:cool:
Jay S 11-20-2024 08:17 PM
I believe that was the forerunner to the cam Paul listed. The next series was a couple degrees bigger with a little more intensity over the nose. I’ve had this in several engines. This is from the intake. Looked like new yet, and I know it had a second set of lifters broken in on it. Probably had 7000 miles on it a 600 1/4 mile passes. Tough cam.
Crane 248/258 SFT
.001 111
.002. 104.6
.003 99.6
.004. 95
.005. 89.6
.006. 84.8
.007. 79.8
.008. 74.8
.009. 70
.010. 65.2
.011. 60.6
.012. 56
.013. 52
.014. 48.2
.015. 45.6
.016. 43.2
.017 41.2
.018. 39.8
.019. 38.2
.020. 37.2
.021. 36.2
.025. 32.2
.030. 29.2
.040. 23.6
.050. 19
.060. 15
.070. 11.4
.080. 8
.090 5
.1. 1.6. Coming up on zero
.110. 1.4 past zero now
.120. 4.6
.130. 7.6
.14. 11.4
.15. 13.4
.2. 28.8
.25. 46
.3. 69.4
.31 76.4
.32. 83.6
.330. 95.6
.3334 max lift
.330. 120.6
.32. 132.8
.31. 140.2
.3. 146.5
.25. 168.8
.2. Passed 180. Going down 174.6
.15. 160
.10. 146
.090. 142.8
.080 139.4
.070. 136.4
.060. 132.8
.050. 129
.040. 124.4
.030. 118.8
.025. 114.8
.021. 110.6
.020. 109.6
.019 107.6
.018. 105.4
.017. 103
.016. 100
.015. 96
.014. 92.4
.013. 88.4
.012. 84
.011. 79.8
.010. 75.6
.009. 71.2
.008. 67
.007. 62.8
.006. 58.6
.005. 54
.004. 49.2
.003. 45
.002. 36
.001. 33
.0005 went to zero
Stan Weiss 11-21-2024 12:46 PM
That cam has some huge lash ramps. Reminds me of the Chevy 30 30 cam.
Stan
GTO-relic 11-22-2024 05:51 AM
this Crane is on a relatively wide LSA 112 degrees, more like the stock GM Pontiac cams, RA III, RA IV, RA V.
whereas today most everything new is cut on a 110 LSA or tighter.
STEELCITYFIREBIRD 11-22-2024 05:49 PM
290/300 adv
248/258 .050
.500/.525
112 LSA
.022/ .022 Lash
Not sure of year of this catalog page, but it’s listed here.
