1974 SD Trans-Am Rear Sway Bar Rubber Grommet Source?
Can anyone suggest a source for a complete replacement set of rubber grommets for the entire rear sway bar assembly, which includes the support rod end links?
Thanks! |
13/16 sway bar
In 74 the sway bar is 13/16
You can get energy suspension kits number 3.5123G |
Red, thanks for the input!
I looked up that P/N, but it says that it is not compatible for 1974 Firebird...your thoughts? |
Thats what i put in my 74 and was perfect fit
Very good and thanks!
| All times are GMT -4. The time now is 04:29 AM. |
