-   -   Camshaft ID (https://forums.maxperformanceinc.com/forums/showthread.php?t=877315)
VCho455 11-24-2024 07:23 PM
Camshaft ID
Anyone have any experience with this cam? I believe it's Comp Cams early version of the XR288HR-10?
Steve C. 11-24-2024 10:51 PM
I suspect the "R' stands for solid roller. If it was a hydraulic roller it might be engraved "HR".
.Just a hunch.
Note here on the solid roller the "288R-10"
https://www.cspracing.com/comp-cams-...22zNTZVXf5iUTt
Another one: https://coastalraceparts.com/product...-CPLYzyY79G-Gu
And yes, the -10 indicates the cam is ground with a 110 LSA
Steve C. 11-24-2024 11:31 PM
To check the lobe lift on a camshaft, measure the largest diameter of the cam lobe (at its highest point) with a digital caliper, then measure the diameter of the base circle
(the flat section between lobes), and subtract the base circle diameter from the lobe diameter to get the lobe lift; essentially, you are calculating the vertical distance the cam lobe rises from its base circle.
Start here....
The XE hydraulic roller lobe 3346 has 0.3060" lobe lift
The XE solid roller lobe 4857 has 0.3350" lobe lift
Both are rated with 288 degrees
Tandyman 11-25-2024 11:20 AM
I have a P288R-10 cam and it is a magnum solid roller. I would say it was a decent working street/strip cam.
Had a fairly racy idle but worked OK with the power brake on my 69 firebird.
It is 244/244 at .050 with .3666 lobe lift with 110 lobe separation.
Glenn
Steve C. 11-25-2024 12:47 PM
COMP Cams Magnum Solid Roller Camshafts 51-751-9
https://www.summitracing.com/parts/c...OCzF8#overview
Same as Comp High Energy Street Roller lobe # 1476 on Page # 71
https://edelbrock-files-v1.s3-us-wes...be-Catalog.pdf
VCho455 11-25-2024 05:39 PM
Glenn
Thanks for the appraisal! How many cubic inches was the engine?
VCho455 11-25-2024 05:47 PM
Thanks everyone for all the information. I got the cam when I bought out a gentleman who had given up on his restoration project. It came in a box with a set of hydraulic roller lifters.
The cam and lifters were supposedly installed and ran less than 50 miles. At that point he decided the cam was too big for him so he had it replaced with a smaller cam. All this was before he disassembled the car to restore it and never finished it.
Tandyman 11-25-2024 07:13 PM
It was a 455 .030 over with 1971 96 heads.
Glenn
