Unobranium Parts Wanted For 1977 TA
Looking for the following - good used or NOS
Factory CB Radio Antenna Deluxe Interior Door Pulls Pit Free Differential Cover 4 speed Console Gauge Temp Sending Unit Thanks. |
I don't think any of that is really that hard to find.
for your door pulls and console, specifying a desired colour might help your cause. :) |
I got a few nOS GM temp sending units
Got door inner and outer handles, in the box. Hard to find both , not cheap |
fair points.
the repop consoles also have plastic brackets... |
The new temp sender from lectric limited reads accurate btw
I may have a really nice diff cover from a 16000 mile car..let me check my stash.
You can also just restore your pitted differential cover. Unless it's severely bad, just fill the pits with products like Permatex 25909; Evercoat Metal 2 Metal; USC All Metal... Diff cover is thick enough that you can even weld or braze new metal into the pits and then just grind down and paint. What's pitted? The outside where it's cosmetically bad, or the sealing surface?
| All times are GMT -4. The time now is 03:26 AM. |
