-   -   Pontiac 4.00” stroker kits (https://forums.maxperformanceinc.com/forums/showthread.php?t=877865)
1950Mercury 12-24-2024 04:31 PM
Is there anyone such as Eagle or ? making 4" stroke cranks or stroker kits for the 389 or 400 blocks with 3" mains? I see many for the longer strokes. I prefer to stay at the 421 or 428 cu. in.
steve25 12-24-2024 05:06 PM
Butler offers a stroker kit for $3200.00that will get you 421 to 428 cid out of a 389.
tom s 12-24-2024 05:07 PM
Molnar.Tom
Quad 12-24-2024 07:13 PM
The Butler stroker kit has Scat forged Crank & Rods. Butler also sell Molnar 4.00 forged crank & 6.700 rods that they may substitute If you asked. For a few dollars more?
ponchjoe 12-27-2024 08:12 AM
There are no cast 4” cranks I can find for a 400 anywhere. Molnar forged is it for about $1200 bucks by the time you ship it
Formulas 12-27-2024 02:41 PM
Molnar sounds expensive until you realize you dont have to get it turned hacked or welded just to use it.. rods or crank ...
PAUL K 12-27-2024 03:30 PM
Do folks realize "stroker kits' are individual crank, rods and pistons that function properly together and come with rings and bearings.
Each part can be purchased separately and from different manufacturers.... that also gives you better options to tailor the parts to your specifications.
1950Mercury 12-31-2024 06:05 PM
I do understand that. I generally use Ross pistons and tell them the compression height I want. I was just wondering about the crank. All I was seeing was the longer stroke which I don't particularly care for. I was sniffing around looking for a 421 or 428 but it seems like the ones out there are pricey. It may be cheaper in the long run to build a 421 from a 389 or maybe a 428 from a 400.
Formulas 12-31-2024 09:13 PM
OEM 428 crank in a 455 block works well also
performerrpm 12-31-2024 10:57 PM
x2.....this is exactly what i have on one of my stands now.
1950Mercury 01-01-2025 07:47 PM
Yes.. That may be considered. Depending on if I find a 400 or6 a 455 at a reasonable price with in driving distance from me. I almost prefer the smaller journals. Just like 327 Chevy. Small journal seems to run stronger.
242177P 01-01-2025 08:05 PM
The Chebby guys sure do love them 383s. Just saying.
blueghoast 01-01-2025 08:07 PM
I'm in Michigan where are you? I've got some 455's
GT
1950Mercury 01-02-2025 05:21 PM
Northern Idaho
1950Mercury 01-02-2025 05:23 PM
They run strong. I'm running 2. One in a 50 Merc. and one in a 34 5 window coupe.
blueghoast 01-03-2025 02:19 AM
Heck yeah.
GT
