68-72 A body Rear end and suspension parts - NW Detroit area
5 Attachment(s)
Hello Pontiac friends. I have some good parts for sale. Changed over to 9".
-12 Bolt Rear from a Chevelle. Stock width. 3.73 thin gear, 4 series carrier, 33 spline Truetrac, welded tubes, solid spacer, 3" 1/2" moser studs, billet yoke 1350, Big ford ends welded by DTS (no c clips) with big drum brakes. Just rebuilt by DTS. Original build and rebuild POs attached. $2,900.00 -UMI Control Arm Braces 4028-B. new 160.00 - $80 -BMR Extreme Anti Roll Bar XSB006H new 500.00 - $300.00 -TRZ adj upper control arms new 229.00 - $125 -UMI lower control arm relocation brackets 4012-B new 150.00 - $75.00 -Dick Miller NO HOP bars the 12 bolt has had these installed - $200.00 -Drive shaft CCI 3.5" DOM steel. Billet yoke 1350s. Was in a 70GTO with a Tremec Magnum 6 speed and the 12 bolt. new 450.00 - $150.00 I can ship smaller items for ups cost. |
pics
5 Attachment(s)
pics
pics2
5 Attachment(s)
pics2
pics3
5 Attachment(s)
pics3
What is the part number on the adjustable upper control arms - may need a set for my 66 Lemans and want to know if compatible
The TRZ arms are 317-201-2. Only 68-72. There is another part # for 64-67
Sent from my iPhone using Tapatalk |
brackets, 12- bolt
Hey Steve, on your 12-bolt what's the , measurement between the backing plates, also interested in your TRZ upper control arms and lower relocating brackets.. PM sent
driveshaft
interested in the drive shaft also.
What is the length of the driveshaft? Thanks
Driveshaft trz uppers and lower relocation brackets sold.
Still have 12 bolt , bmr anti roll bar, no hop bars and braces. Sent from my iPhone using Tapatalk |
Bump - Rear now $2700. Also have the other parts from last reply.
Bumping. Make a reasonable offer on the 12 bolt via PM. Still have other suspension parts below.
bump...rear end, no hop bars, stiffeners, trz upper spherical joints available.
PM sent.
| All times are GMT -4. The time now is 07:43 AM. |
