-   67-81 Firebird & TA Parts WANTED (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=452)
-   -   72-74 Carb Tee (https://forums.maxperformanceinc.com/forums/showthread.php?t=878019)
SD73 01-02-2025 11:06 PM
72-74 Carb Tee
Hello folks, anyone got a two porter like this one I could buy? Please PM me a price. Thanks!
https://forums.maxperformanceinc.com...1&d=1735873487
4dblnkldude 01-04-2025 08:51 AM
I did buy one of them from Ames two years ago. They may still have them or are you looking for an original?
SD73 01-04-2025 12:58 PM
Yep, looking for an original. The only repro I've seen is the one with the additional port or the one with the brake port going straight back.
unruhjonny 01-16-2025 04:32 PM
has anyone successfully rethreaded an original one?
I have a spare, but the threads are crap.
SD73 01-16-2025 10:28 PM
I've heard of people doing it with some success. The issue is that it's a tapered thread so it won't go in far if the taper isn't correct. The other thing is if you don't get lucky on where it seat you may have a fitting that's 180 degrees off from where you want it.
gtopaul13 01-18-2025 05:48 PM
should have 413 229 8652
SD73 01-19-2025 01:06 PM
Hello Paul, just left you a message.
SD73 01-19-2025 05:42 PM
GTOPaul didn't have the right one, so still looking...
yahooskidoo 02-01-2025 10:14 PM
3 port tee
I have an original 3 port tee if that will work for you.
SD73 02-02-2025 01:02 AM
I appreciate the offer. I've got something that works for now, so I'll hold out for a 2 porter.
