-   67-81 Firebird & TA Parts WANTED (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=452)
-   -   1968 ST300 Shifter Cable and transmission bracket (https://forums.maxperformanceinc.com/forums/showthread.php?t=878040)
wwilder9 01-03-2025 10:31 PM
Hello everyone,
I have an original engine 350 2 barrel car with a 2 speed ST300 transmision, Back in the 90 when I first restored this car, I was jacking up the body off the sub frame so I could repair the subframe and replace the bushings and I forgot to disconnect the shift cable and stretched and bent it having to replace it, nobody had a replacement so I put a later 2nd generation shifter cable in it and my neighbor at the time cut and welded the shifter bracket that bolts to the transmission, so the shifter does not line up corrctly in the car but is functional, I would like to try and find the original cable and bracket for the ST300 with floor shift, anyone have any idea where to look, I can't find them anywhere and dont think they are reproduced.
Thanks in advance.
Scott Thelander 01-04-2025 07:31 AM
I have the cable bracket for the trans if needed,
I dont think I have a cable but I will look this weekend
wwilder9 01-04-2025 11:07 AM
PM sent
wwilder9 06-27-2026 10:16 PM
Still looking for correct cable and transmission shifter bracket.
