66 Full Size 4 Speed Pedal Help
I have 3 sets of what I'm pretty sure are 1966 full size pedals. 1 of the assemblies has the clutch and brake on the same shaft. Set on left in photo. The other 2 have the brake pedal on a shaft much higher in the bracket. Can anyone shed some light on this difference ? I am converting a 66 2+2 to stick and trying to pull everything together. Thanks
I would need to do more research but as a quick suggestion did power brake cars use a different pedal pivot point than may have been used for manual brake cars. 66 full size probably had a lot more power brakes than manual brakes.
Thank you for this info. I don't see many full size manual brake cars.
Cool. You got 2 sets of manual brake pedals. Rare.
| All times are GMT -4. The time now is 01:43 AM. |
