-   Tri-Power Tech (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=569)
-   -   help before I buy - 64 tri power (https://forums.maxperformanceinc.com/forums/showthread.php?t=879245)
tempeonempty 03-08-2025 12:35 AM
2 Attachment(s)
I'm wondering if the experts can chime in and get me a stamp of approval or tell me what is wrong with this set up. Seller believes it carbs are original to intake, removed from a 64 gto.
Also curious what a ball park price might be to purchase missing components and perhaps replate them?
Thanks in advance for your help
tempeonempty 03-08-2025 12:49 AM
PS, I am sorry about the second picture being upside down... I can not get it to load on here right side up
dhcarguy 03-08-2025 11:42 AM
I would ask them to remove the air horns and list the part #'s on the under side.
sould be: Front and rear #7013206 center: #7017917
Float bowls- Front and rear: #'s : 7029683. Center # (AT) 7019929, (ST) 7019927
Manifold #9775088
Every thing you need to restore is available at pontiactripower.com or Dick Boneske @920-450-1040
mike w 03-13-2025 09:43 PM
64 tripower help
I see at least one issue with the set up. Feel free to call me, Mike Wasson, 309-360-6385.
I have no intention of trying to sell you anything; just offering my help.
Pepper Judge 03-16-2025 12:17 PM
https://forums.maxperformanceinc.com...3&d=1742141666
Here you go
Dick Boneske 03-17-2025 04:15 PM
Center carb is correct. End carbs are real Pontiac Tri-Power, but '63 or older. This is not an issue, as they are nearly identical to the '64-'66 end carbs. No need to take the tops off the carbs, as they are definitely correct.
Manifold and thermostat housing is correct for a '64 GTO. The hard-to-find brass TEE fitting is there, in the center carb base.
I would offer between $750 and $900 for the setup.
I do Tri-Power restorations. I can restore those carbs, add mechanical linkage, and fuel lines. The carbs would be dichromated like the factory did, steel parts plated, bases rebuilt, colored, and DAG213 applied to the end carb throttle plates.
If your car has an aftermarket cam, I will calibrate the carbs to run and idle well with whatever cam you have. I would need the cam specs.
Here is a picture of a '64 setup I recently did.
Goatracer1 03-17-2025 06:05 PM
First of all I know that it is a lot of work and money to correctly restore a Tri power set up. My question is where do you find a set that is anywhere near correct for less than $1500? Most people selling a set think it is worth an arm and a leg even when it is just a collection of misc. parts. I have a set of 1964's, 1965's and 1966's that I will not sell. Although not absolutely correct they are close. (The 1966 middle carb is one of Ames' old reproductions). I've had them 25-30 years now and being 77 years old I'll probable never use them maybe my boys will. They were all good running units and with new kits would be again.
tempeonempty 03-17-2025 10:37 PM
I've been looking for a set of 64 carbs for almost a year now. I see most people asking 2500 (for complete intake/carbs). I missed out on a couple original sets for $800-$900. They sell fast at that price! You are right most are a pile of parts thrown together.
I found this piece on marketplace, I was out of town visiting family so I had to make a quick decision. the 997 end carbs listed as 63 threw me off. But this is a Jan intake so based on what I've been reading it may be legit(?). I ended up buying it for $1,000. A little more than I wanted to spend but I figured I didn't have to pay shipping...
I'll reach out to Dick and Mike for more info.... Thanks all!
Dick Boneske 03-21-2025 01:14 PM
You can find a correct restorable '64 setup for $800-/$1000. Remember, the center carbs are identical for '61-'65, except for some automatic versions with hot idle compensators. The end carbs from '64-'66 are also identical.
You can use the '59-'63 end carbs (997's) on a '64 setup. They are the same as the 683 versions used from '64-'66, with minor cosmetic differences, no differences in performance except that the throttles only open 2/3. This is an easy fix. The earlier center carbs (1959-1960) can be used with minor cosmetic differences.
Contact me for misc. parts and/or complete carbs.
Goatracer1 03-21-2025 05:13 PM
Maybe in Wisconsin you can find a correct any year set up for $800 but not any place near me. You are lucky.
