Hood Spring Help
When I bought my '69 GTO it had already been restored. I immediately noticed that the hood springs were really "weak" - meaning that they barely kept the hood raised. Any slight breeze or even opening the door and sitting in the car when the hood was raised would cause the hood to come crashing down.
So I purchased a reproduction hood hinge & spring kit. I was disappointed to find that once installed and aligned properly, the situation only slightly improved. The hood still closes much too easily. It's bad enough that I'm afraid to raise the hood at a cruise-in or show for fear that the hood will slam down on someone. Does someone make a set of "heavy duty" springs for my car (or know of another set of springs that'll fit) that might solve this issue? TIA for any advice! |
Buy the Ames springs part # D130. I had the same problem. Put these on and problem solved.
Same problem with my 68 Firebird. Stock replacement from Rock Auto fixed it.
Looked on line and couldnt find D130. Went to their actual paper catalog and they list it? Finally figured out that D130 is the application for 66-67 GTO's. Since I was searching for hinges for a '69 it never showed up. LOL Springs are ordered, and fingers crossed they solve my issue. Thanks for the guidance!! |
Here is what You need!
https://www.amesperf.com/parts/searc...lts/?term=d131 |
Update: The D130 springs were ordered and installed. They seem to have solved the issue! Thanks to everyone who weighed in to help!
My 69 bird had the same issue,I found some Volvo springs that fit inside the stock GM springs and it cured it.Can be installed with the originals on the car.Tom
I dont,been a few years.I did a search at the time,will see if I can find it.Tom
I think they were Volvo 140-142 springs.They fit inside the firebird springs.No guarantee but they look like what I used.Tom
Thank you
| All times are GMT -4. The time now is 05:25 AM. |
