Electrical Question
I’m running plastic conduit using 12 gauge THHN wire. Since it’s a stranded wire, is there something that goes on the end before I put it into the outlet? Also since I have to go into a junction box first, can they be wire nutted together?
You can wire nut in a junction box as long as it remains accessible. On the outlet you will need to use the side terminals. The stab holes are for solid wire only.
Put the U shaped terminals on the ends.
| All times are GMT -4. The time now is 12:10 AM. |
